Mazda Engine General \  header?
header?
views 575
replies 3
following 2
rob   +1y
so can someone send me a correct link for a header fitting a 86 b2000 and tell me everything im going to have to do to get to it to fit.. Thanks
Rob
hocbj23   +1y
Not but one that I know of and that is PAcesetter.See them on eBay all the time.If u put a header on u will lose the terminal end of ur pollution crap so u need to change to a Webber carb at the same time.If u keep Nikki carb u will need to weld a bung in ur exhaust pipe for ur o2 sensor.U will need to block off the two pipes from ur air cleaner that go down to the exhaust system.If u have a/t u might need to flatten the last pipe on the header to clear the a/t bell housing.
That is about it.BJ
rob   +1y
well im going to be getting rid of all of the emisson shit and im getting a weber 38 so what fabrication will i have to do then??
Rob
hocbj23   +1y
Exaust pipe from header flange to 2 nd cat.By the way,MagnaFlow makes a great cat with 2.25 inlet and outlet for $55 that I would get.Ur old cat is probaBLY stopped up as mine was.BJ
