Alternator
Alternator
maztang (ryan)'s avatar
maztang (ryan)
I want to get a better alternator for my truck. I called an alternator repair shop today and they said it would cost about 50-60 bucks for a stock rebuild, so i asked how much to beef it up? the dude asked how much i wanted to spend. haha. he said that a good beefed up alternator runs anywhere from 200 up to 500 bucks. is this right? where can i go to get a beefier alternator for this truck?
fanninator's avatar
fanninator
i have heard ofpeople using the gm one wire ones. they are 100amp i think. they say you need to mod the bracket tho. i plan on doing this on down the road. -bf
maztang (ryan)
^^^ anyone know what year model or anything that this comes off of? i need a new alternator bad and i really don't want to buy a stock alt. unless i have to.
nytrdr24's avatar
nytrdr24
last i checked a place here in town would rebuild & wind one of our factory units for about $120........this was going from the stock 50-55 amp output to 90 amp.
i know the one wire units came on the early 80's gm trucks.....
maztang (ryan)
ok see i talked to an alternator rebuild shop here and they told me they could rebuild it for 50 or 60 bucks which i thought was cool. but when i asked him to beef it up a little he said he didn't think he could. 90 amps would be plenty for what i want. i wonder what all they have to do to the internals?
bagdb2200
The FC RX-7s alternators use the same case and are 70amp. The plugs might be different though.
baggedb22
I have a GM 1 wire on mine but my mazda is also v8ed, there not hard to wire at all and u can get new ones for under 200, i got a remaned one from the local junk yard a 100amp for $30 i may be up grading to a 200 amp though with the dual batterys in the near future...
nytrdr24's avatar
nytrdr24
a little extra copper on the windings & upgrade the brushes....not that much...it's just time consuming & the cost of the parts & extra copper.
maztang (ryan)
coo. i need to pull the alt. off of my parts truck and send it in to get rebuilt before this one leaves me hanging. thanks for all the info guys.
hex0rz
Place call wrangler makes an alternator for our trucks. They're high output and mine is 190 amps at idle. I have my soundsystem and it draws 135 amps alone. Plus future bag setup and amps needed for engine to run good. So depending on what you want done, plan on spending some good money for one. I got mine for $400 and also the cost for a belt 2 inches longer. Had to upgrade to 0ga wires also. Installed it myself and had no problems!
kia swap
last post by Brody 12 mo
51
