trans problem.....
trans problem.....
carolinasled
ever since i bought this truck it's hard to find reverse.... i have to cram the clutch to the floor and ease on the gas barely to here it shift into reverse. and sometimes that trick doesnt work, and it makes a grinding noise....
now 1,2,3,4,5 or fine but reverse is scrwedup....could this be the synchronizers going bad or have already went bad.... if so do they make a transmission rebuild kit???
would i be better off rebuilding or finding a trans????
thanks guys
2fine89's avatar
2fine89
try shifting into fourth before moving over into reverse.
I have done this for years - dunno what it does - lines up the synchro's or something ?? give it a try anyway.
fanninator's avatar
fanninator
me to....i make sure i am stopped 100% then hit 1st then reverse...works everytime! -bf
carolinasled
ok i'll try these methods, but are the synchronizers going bad????
nonamedsomebody's avatar
nonamedsomebody
I have always heard manual transmissions don't have a syncro for reverese thats why they grind, Mine grinds when going into reverse to I just pop the cluch a little seems to do the trick.
pont's avatar
pont
My 86 did not have rev somethings I heard that can cuase it are
bad pilot berring
and bad input shaft berring
now mine was gone all the way it would take it but as soon as you let out the clutch it would pop out.
kia swap
last post by Brody +1y
51
