Mazda Engine General \  weber jets.
weber jets.
views 522
replies 3
90b2200   +1y
what jet should i be runnin in my weber?
i dont know which one is in there right now but its doesnt seem to run right.
it idles bad.
it waz a used weber i got off ebay. its a DGAV with tha upgraded electric choke on it already.
i would like to know which Main Jet and the Idle Jet.
Thanx N|ck
drpdmazda   +1y
when you put the carb on did you do a tune up on the truck? new plugs, wires cap rotor etc? if not oyu may want to try that as its recomended with a weber install, they are very hard to tune, i know mine tok a long time to dial in correctly, check all your basic stuff before you try to change the jets, the stuff i said above and check your timing as well
nytrdr24   +1y
look on this site...they have some good info about webers...if nothing else give them a call.
90b2200   +1y
aight guys thanx for tha help i wll try it out.
Thanx again,
N|ck
