a little help if possible
lowlifej avatar
lowlifej
Working on the front of a 93 Space Cab just wondering how everybody does there shock towers where your uca bolts? Ive scalloped the frame and was wondering if anyone had any good pics of of there setups running 20s in the front and need as much lift as possible.
thanks Jeremy
lowlifej avatar
lowlifej
Somebody please lol
baha avatar
I'm not sure what you mean for the shock towers? What are you doing to your suspension? Are you installing air suspension?
lowlifej avatar
lowlifej
yea im in the process of bagging the front of it and heard of guys rebuilding where your upper a arm bolts on. Hell id just like to see some diff front setups for the front!
baha avatar
Oh for bags you almost have to eliminate the stock shock mounts. On my Toyota which shares a near identical frame set up I didn't need to cut off the frame mounts but I did remove the stock shock mount. A common set up is to build or run tubular upper control arms and use link tabs to mount them to the frame. I'll try to find some pics.
lowlifej avatar
lowlifej
thanks man
