Mazda Engine General \  Vacuum line elimination
views 589
replies 4
fantomrush   +1y
Im relocating everything on the passenger fender now. I cut it out and I am rerouting everything and moving it. Im trying to figure out what I can get rid of without affecting the way to truck runs. I plan on getting rid of the exhuast lines that run up to the air cleaner. With that being removed it looks like I can eliminate the the #1 & #2 air control valve, the duty selonoid valve, the ACV selonoid valve and the EGR control valve. It also looks like I may be able to get rid of the vacuum selonoid valve.
Does this sound like it would work and not make the truck run crappy. Another thing I should mention is we have emission tests here. Will removing this stuff make the truck not pass emission?
This vacuum crap is a nightmare! Ill be glad when I get a weber to put on it.
fantomrush   +1y
anyone?
pont   +1y
It could make you fail emissions. With out it the stock carb will run rich with will make you fail the emissions and give you crappy gas milage plus put ware on the motor I would keep it all till you got a weber then it can all go.
southernrazed   +1y
yea if thers an emmisions test yer gonna fail...egr is emmisions device.
fantomrush   +1y
well crap... I guess I need to find a place to put all this crap. lol
