issues
richie
ok so heres teh deal occasionally like every other drive , after bout 3 mins of driving my truck will start to hesitate and bog out under load while trying to aquire speed, let off the gas runs fine, step on it revs nice and high then starts to bog out, but will not stall,, shut it offf and restart then it will drive fine for a block or sooo...but only every other cruise but always for the whole cruise! let me know
richie
ideres?
lost_b2200
I was going to say fuel filter, but that should affect it all the time. IDK for sure but I'm quite sure someone does.
maztang (ryan)'s avatar
maztang (ryan)
hey man, i read this before but didn't even think about it. in my 65 mustang i had this exact same problem only the car would completely die and i would have to wait a minute to crank it back up. we searched forever to figure out what the problem was and all it was, was a kinked fuel line. so i would check all your fuel lines and make sure none of them or kinked.
pont's avatar
pont
I would say fuel filter kinked fuel line like the others have said. That would be a good place to start. What kind of lifters do you have. Mine was doing some what the same thing. Turns out one of my Hyd lifters went bad. Even though it was not clicking. Swaped them out with the manual ones and fixed the problem.
richie
fuel lines are all good, and new fuel filter
southernrazed
well next step would be to throw a timing light on 'er also check for vacum leaks..
maztang (ryan)
are you running a weber or the stock carburetor?
richie
stock carb
and as for timing how can timing go out in a weekend, like i drove it and then all of a sudden it started
maztang (ryan)
have you checked your plugs? could have a fouled plug or 2. also try some seafoam in the fuel system.
kia swap
last post by Brody +1y
51
