i have a b2000 motor and was wonering does everything on the b2200 bolt up including the clutch and tranny. Also will the b2200 mount directly in my truck with little modifications
hocbj23
Yes and yes with a couple of exceptions.Dont put a 2200 head on a 2000 block and vice versa.2000's use mechanical lifters and 2200s use hydraulics. 2000 oil pump will not get enough oil to top end to keep 2200 lifters supplied and 2200 pump will oversupply the mechanical lifters and cause oil erosion problems.Other than that I cant think of any other issues other than maybe some minor wiring differences.BJ
lost_b2200
So if doing this the 2.0 oil pump should be used?
8
86mazda
is there a reason for using the 2.0 oil pump
pont
head up 2.0 Head down 2.2 use everything for the 2.2 but the lifters the 2.0 manual lifters are alot better just done that swap myself
lost_b2200
I got confused between posts. I read another post I definatly want the solid lifters if they are more reliable and less noisy!
pont
Only thing about the solid lifters is they must be adjusted from time to time (most the time at tuneup) other than that there great. and the Heads will fit ether block with no problems but the lifters will not. The hyd lifters will not work on a 2.0 block cause there will not be enough oil to make them work and they will tap. But the solid will work on ether. just remember to Keep the cam caps with the proper head.
