hey guys i have a few questions here. ok i am working on building my motor now i was wondering how big could i bore a 2.2 block? i planned on putting a 2.2 block with 2.0 head running a pace header and weber carb. lemme know how you think that will work also i need to know where i can get my cam ground and what the best specs are for this? how much does it usually run? o yeah i also plan on extrude honing the head. now what are my intake options? s the 2.2 intake same size? are there some aftermarket ones out there? can i extrude hone the intake? lemme know what yall recommend.
slammedmini469
by the time you sink all that money into the stock engine, you could have picked up a low mileage fe3 (sportage) engine and had the same or more HP....
or even a f2t probe/mx6 engine, but it would have higher mileage
devb22
Good man good man!
Dev
nytrdr24
you can do like they said, but since you already building your 2.2 here are a few places that ought to help you out.
you can get most of the rebuild parts from import, paeco offers custom stuff such as the cam grinding, & thermoburr is a subsidiary of extrude hone & depending on your location they probably have a site close to you to do that.
if you need more info, hit me up, i'll be glad to help you out!
