Mazda Engine General \  4.0 SOHC
4.0 SOHC
views 772
replies 8
following 6
widowb   +1y
i bought a 2001 ford ranger 4.0 Sohc and tranny 4wd. so it needs to be converted which is no problem for me, i orderded the parts thru work today. its goin in my 1986 b-2000 so it should be sick. as soon as i get the money its going supercharged... ill let you know how the install goes..
yes i am a 19 yearold who cares nothing for anything but my truck and my family, every dime i get goes into the truck... lifes better that way
gravity5   +1y
Not a bad motor...there ar elots of 4.0 performance sites out there...
mark   +1y
Yes that is a great motor.
That motor pushes around the 200hp mark off of the crank. There is a guy that swapped the 4.0 SOHC in for his 4.0 OHV in a 5spd, std. cab ranger and used the OHV computer with factory drivetrain. The truck ran low 14's in the quarter mile on street tires. Keep in mind this is using the OHV computer. Not sure if he ever got it re-tuned.
Those motors are very well capable, and in a little mazda, supercharged would be one fast little street driven truck. Make sure to get the 5speed! The 5spd automatic tranny that comes with the 4.0 SOHC aren't bad at all, but you'd really do it good with a 5spd.
limequat   +1y
...Or get the proper bellhousing and bolt it to a mazda 5 speed.
mark   +1y
Where can you get the proper bellhousing?
Or are you talking about the 94+ Mazda 5spd.
limequat   +1y
I think it is used in F150s with the 4.0. Bolts a Ford motor to a Mazda trans.
baggedb22   +1y
f-150's dont come with a 4.0??? only explorers,rangers,aerostars???
slammedmini469   +1y
f150's with 6 cylinders are either 300ci I-6's (up to 96) or 4.2 v6's (97+)
gravity5   +1y
the 94 - 2000 mazdas with the 4.0 5 speed use a mazda tranny, it bolts right up. Or you can get the tranny from the 05 mustang....there is a kit that makes those work too...and there is a kit for a t-5 tranny from a 5 liter motor as well.
