Mazda Engine General \  do i need a oil pan gasget
views 535
replies 6
oregonmazdoger   +1y
i was reading my mazda book and it said that there are 2 options rvt or a gasket but it dosn't tell how to determain if you need one or not
maztang (ryan)   +1y
cork gasket with rtv to hold it in place. do not install the rtv on the entire pan just on a few spots to hold it in place. you should be able to get the gasket at your local auto parts store for under 10 bucks.
oregonmazdoger   +1y
thanks i all ready got the gasket just didn't know if i needed it or not cus book said theres 2 options rvt or cork and when i took it off all it had was rvt
madlowmazda   +1y
You are right, the book and mazda says just use rtv... that's all the factor had on it- and that's all I use on them-
Cork is going to absorb oil and leak like a bitch- throw that cork away!
oregonmazdoger   +1y
i allready instaled it with a little rvt on it
maztang (ryan)   +1y
i have never had a problem with the cork gaskets leaking. unless i reused one. i've done that before and it didn't work out too well.
devb22   +1y
I think you will be okay, just keep an eye on it!
Cork isn't the best gasket, but its a lot better than nothing. I would have picked up a Fel-Pro Permadry gasket!
Good Luck!
Dev
