throttle cable routing for weber
F
lowblownranger
well my weber cam today can some of you post pics of how you routed your throttle cable.... i have an idea of how im going to do it just wanna see if anyone came up with any easier way
lowblownranger
any one ??
8
89b2200
Did you get the weber conversion kit or just the carb?
The kit comes with all the necessary parts you need.
If not, you have to be creative with what you got.
The cable routes between the firewall and carb.
Post a pic of the weber you got.
hex0rz
Yes, hopefully you have the full conversion kit! If not, you are going to have to get creative and make some sort of bracket! I've got an import store in my city that sells spare parts for the weber and the whole kit. Hope you have one too!
If you happen to have the full kit, it will be very easy to route your cable. If you have a kick down cable, you won't be able to use it but thats okay. Use the accel cable from your pedal and keep the whole thing. There will be like two nuts on it with a rubber grommet type piece that can use to mount it on the cable with. I adjusted the cable accordingly so that it would idle, but not also have any slack and not too much tension. You should figure it out eventually. Just adjust it, turn the engine on, and do a trial and error.
If thats not enough, I can try and get a pic of mine up for you...
lowblownranger
no unfortunitly i didnt get the whole kit... wife got it for me for my birthday.... the throttle linkqage for the cable to pull it will have to be mounted so the linkage is towards the firewall... other wise it wont pull it open... i have a good idea of how im going to do it...... just wondered if anyone else had an easier way.... ill post a pic sometime today
kia swap
last post by Brody +1y
51
