Mazda Engine General \  erg valve removal
erg valve removal
views 1011
replies 12
following 6
mazdabon2nd   +1y
i have a weber set up with all the emission stuff removed except for the egr valve has anyone jus used a piece of metal to block it off to get more power or anythin like that to jus remove it so it looks better i kno when my truck is running and i aply vacum to the egr valve to open it up it stalls sooo can anyone help me out thankyou
derek
nytrdr24   +1y
yes, you can remove it & make a block off plate, just be sure to make a gasket or use some good rtv sealand.....
maztang (ryan)   +1y
i thought you had to keep the egr valve for some crazy reason?
nytrdr24   +1y
w/o all the emissions junk & nothing hooked to it, you shouldn't
need it.......it is just taking up space in the manifold.....
maztang (ryan)   +1y
ok, i guess i can get rid of mine then.
nytrdr24   +1y
if this darned thing will quit making me have to re-loggin in, i will pm you maztang!
mazdatweaker   +1y
post deleted
Post was last edited on May 13, 2009 01:05. This post has been edited 1 times.
1lob2k   +1y
does anyone have a picture of the egr valve? I have a part on my manifold that I cant figure out, it's held on with two bolts, and has a vac. run to it, also it hooks in to the throttle butterfly thing, is this the egr valve solenoid? please help ASAP
nytrdr24   +1y
the egr valve is held on w/ 4 bolts, if lookin @ the mani bolted to the head, it will be on the passenger side of the manifold right under the carb.
hex0rz   +1y
Wait! So what do us Weber guys do about it? Are we not risking the well-being of our engine? I don't like detonation! lol.
