Let me apologize in advance if this has already been posted elsewhere in the forum, but I've yet to get the hang of this search engine. I just bought a used Weber K675-M off ebay, and just noticed that it's the manual choke, not the electric choke that I thought it would be (you think that the M in the name would give it away, eh?) I was just wondering if anyone here has installed one of these on a 91 B2200, and if so, how they ran the choke cable and such. Also, being that the stock carb has a crap load of vacuum lines going to it, is there any that can be eliminated while I do the swap?
Thanks for the help!
Gregg
8
89b2200
If you can install it with no problems i.e, have an adapter plate and retrofit throttle cable, then the choke cable should be easy.
Go to NAPA and get a choke cable kit and you should be able to retrofit it.
lowblownranger
you can eliminate all but the vacumm advace to the distributor
greggoryh
Sweeeeeet You guys made my day. I was really hoping I wouldn't need to find hook ups for all those vacuum lines. That would have been a nightmare!
