Mechanical Fuel Pump
brian_dring@yahoo.com's avatar
87mazdamini's avatar
87mazdamini
Do they make a noise sometimes when they are going out? Like if the arm that rests on the cam is getting worn and loose?
87mazdamini
anybody? I adjusted my valve lash and have no more tick. sometimes I get a low idle and when cruising at highway speed sometimes it cuts out for a sec.
hex0rz
Man, sorry that no one has posted up to help you! I myself have'nt experienced this. I don't believe it should make any noise at all, even if its going out. I think its something else?
When mech. fuel pumps go out, you can tell by the safeguard they put in it. They've got a hole in it so it will leak gas when the diaphragm goes out.
87mazdamini
cool thanks, it does kinda look like its leaking but not a major leak. I have a new one just have to put it in.
hex0rz
Fuel pump won't even take you 30 min. to replace! If the noise does'nt stop there, then post back up. We may be able to help you more!
kia swap
last post by Brody +1y
51
