Mazda Engine General \  383 stroker in the mazda
views 1578
replies 13
following 10
dr bob   +1y
well i was wondering if i can put one in the mazda.i got a big block 350 boared out to a 383 stroker and wondering if this will fit in a 05 mazda b2300.what kinf od mods will i need to do cut the wheel welds shave the fire wall?any info will help thanks alot
hambandit   +1y
a 383 is a small block chevy for starters. same block as a 305, 327, 350, 355, etc.
and yes it will fit.
dr bob   +1y
its a big block 350 or atleast thats what my dad told me when i pulled it from the old truck and rebuilt it then it was bored out and stroked
v8mazda4ever   +1y
dude not to piss you off but chevy big blocks are 396,454,502 and the big daddy 572 they never built a 350 big block.But to answer your question yes we can put one in and there is alot to do with the newer models to fit it in.And there is a 400 small block and the 383 is just a 400 small block with the crank put in the 350 as I believe
rutter0907   +1y
yeh, it's putting out more power, but the other guys are right this is a small block. look up 350 in anyu parts magazine it will list it under small block parts.........
dr bob   +1y
nah man u aint pissin me off or nothing thats just what i was told by my dad but i kinda thought it was a small block cause there were no parts what so ever for a 350 big block but its not a big deal thanks for the knowledge though.but one thing i was wondering the trans in now wont match up will it?
ranger11   +1y
Go with a 302 or 351 ford alot easier. To answer your question no the trans will not work. You may need to do alot more research before you take any thing out. Alot of things need to be changed when you do an engine swap.
baggedb22   +1y
yea man i have a 351w and a c6 in my 90 mazda its pretty much a bullet proof set-up and its not that hard to install u just gotta be able to fabricate, wire, and cut=)
pont   +1y
don't forget the 400 big block even though it is a Pontiac. (still GM)
v8mazda4ever   +1y
dr bob if you want to put a chevy motor in your truck pm me and I will try and help with some diagrams on the install as you are putting this in a 2005 mazda not an 86 to 93 style way different on the parts and the install.
