weber going in this weekend
F
fantomrush
I just got a weber and Im ready to install it. I bought it from mazdaproject89 and got a good deal on it. I need to get some misc. bolts, screws, and a couple of gaskets. Im hoping I can find the gaskets I need at a local auto parts store. I also need to get a filter and clips for it or find an adapter to use a different filter. I might build a sheetmetal cover for it since I dont have inner fenders and drive mine daily. I dont want to sling water and dirt into the carb or filter.
I didn't get any instructions with it since I bought it used. I knew there were instructions on mazdatruckin so I was going to use those. My problem there is they say I need a fuel pressure regulator cause the B2200 and B2000 use a high pressure fuel system. Is this true? If so, where do I get a fuel pressure regulator that would work? I haven't seem anyone else using a FPR to install their webers.
devb22's avatar
devb22
Good luck on the install my friend....
Take a ton of pictures and make yourself useful and do a Write-Up......lol
But seriously, take some good pics!
Dev
pepehn
mine works good with my stock stuff, i just got mine in not even a week ago. after some minor tuning you'll be amazed at the difference it can make.
i didn't even use my instructions for the most part lol.
pepehn
also...if your worried about dirt, and water and what not you can buy remote filters for these carbs. if i can remember right NYTRDR24 had a remote filter with a 38 he was sellin?
F
fantomrush
Its looking like it might not make it on this weekend. I cant find a gasket or a filter for it local. Im going to have to order one and wait for it to get here.
Oh well...
hex0rz
Ah man! Hey, no worries! Get a DIY gasket sheet! Cut them all out, double them up, and buy Permatex sealant. It does'nt harden and is non-silicone based. I had a problem a while ago with my carb whistling through the gaskets. So the sealant worked GREAT!
Hit up Redline, they should have a rebuild kit for the carb. It will come with all the parts, but it will also have gaskets and an AIR FILTER! And refer to my techie for tuning! I want to know it was worth writing... lol!
kia swap
last post by Brody +1y
51
