What can I get rid of??
pocket_rocket05@hotmail.com's avatar
devb22's avatar
devb22
Well I am starting to clean up the engine bay now that I have my trailor fenders in, and need to know what I can get rid of?
I'm doing a 350 swap next winter so I won't be buying a Weber anytime soon!
I just want to get some junk outa there and make it cleaner...
Thanks!
Dev
devb22's avatar
devb22
Bump....
Dev
hocbj23
R u still running the factory Nikki or do u not have an engine at all in the bay and r just wondering what u can lose?If u r running a stock engine and carb u need everything in there.If u start jerking pollution crap off and undoing wiring harnesses,u run the risk of the carb defaulting to "limp home" mode where it just barely runs.If u got an empty bay prepping for the swap,lose it all except brake booster,fuse box ,wiper washer reservoir and lines,wiper motor,and charcoal canister.BJ
devb22's avatar
devb22
Thats what I needed to know!
I was pretty sure that all of it needed to stay there!
Thanks
Dev
hocbj23
Welcome.BJ
b22bmber
what can u take off if u have the 2.2efi?? got a shit load of electronics on the passenger side fender well and have to cut them out so my tires wont rub after i get my bags in
what can go
what must stay?
F
fantomrush
You can loose the EGR stuff. Just leave the valve there. I lost the EGR stuff and the vacuum stuff on the front of the air cleaner and I haven't had any problems.
It runs a little rich when it's first started and gives me a rough idle, but as soon as it warms up it's fine. I'm also getting about 28 to 30 mpg right now too. I rebuilt my carb about 1500 miles ago.
speedster93b's avatar
speedster93b
i disagree with BJ. he has a good point about not wanting limp home mode. but i don't think it'll happen by pulling your vacuum lines and such off. i run mine with ALL the vacuum lines removed and plugged except the distributor and brake booster. those gotta stay. also i kept all sensors plugged in and it got rid of a lotta stuff.
kia swap
last post by Brody +1y
51
