Mazda Engine General \  missing-smokes at cold start
views 814
replies 6
following 6
b22bmber   +1y
wuts up - got a 93 b22 ext cab
2.2 efi ...it smokes when it wants to when i start it and it sets for a while ..like over night and when its cold it misses like hell around 3000 rpms in every gear...other than that runs fine..has good compression...new plugs and wires...checked the dist. cap...ANY IDEAS????
ALSO curious on how much work there is to switch the motor over to carb. and put a fat shiney weber on top of it?? let me know
mazdabon2nd   +1y
well it could jus be cold or maybe your plugs or timming or how your choke is a adjusted or your thermostat is stuck open so it doesnt warm up fully
hocbj23   +1y
How many miles on truck?Most Maz's with any miles blow a little smoke when first started if they have been sitting up.Using a Maz oil filter will help some . Missing at hi rpm usually means something electrical is breaking down under a load.Did u chang ur dist cap when u tuned it up?How about the rotor button?BJ
whiteyb22   +1y
When the motor smokes at start up and does not smoke during running it is the valve seals when the motor shuts down a little bit of oil leaks past the valve stems and seals and collects in the cylinder.
If it were rings the truck would smoke all the time.
mazdatweaker   +1y
post deleted
Post was last edited on May 14, 2009 03:05. This post has been edited 1 times.
hocbj23   +1y
I second the Tweakers post.BJ
red_b2200   +1y
my truck has 187,000 miles on it and it smokes like crazt when i start it up on cold mornings, but so do all my friends so i dont think the smoking is anything to be to waorried about.
