changing o-rings in injectors
carolinasled
i figured out it was the first injector in line at the front of the truck that is leaking. How do i change the o-rings and rubber washers on this? i have no idea how to and inteneded on doing this saturday night so i need a heads up.
do these injectors just pull out?
do i need to remove the fuel rail above the injectors?
thanks guys.
reflectorcollector's avatar
reflectorcollector
i believe they just pull out of the rail but not for sure...im doing a 86 626 turbo swap which has the same fuel injection system but i have not messed around with the intake manifold except for cleaning it
When you get the injectors out they should just have rubber o-rings that you replace but also not for sure
just see if you can get them out and you should have no problems from there
good luck
kia swap
last post by Brody +1y
51
