bleeding.
fanninator@yahoo.com's avatar
bleeding.
fanninator's avatar
fanninator
i know this is a stupid question, but how do you bleed a mazda? my bro busted a brake line and my dad fixed it for me but neither onof us have bled brakes, we were always the pumpers...wow we sound like a couple of dead asses huh? -bf
speedster93b's avatar
speedster93b
have one of you pumpers pump and the other one should go to the... you didn't specify front or rear...
FRONT: there's a little 5/32 or something small like that prolly 6mm i don't know its small tho!!! bleeder screw on top of the caliper. have one person pump and hold the brake pedal and you loosen it till the fluid shoots out. at first it'll spirt (fluid-air-fluid-air-fluid you get the picture) really fast. that's the air coming out. let it spirt a bit then close it off. then let the pumper pump again and hold and do it again. and again until you get a solid stream of brake fluid. make sure your master cyl doesn't get low or you just wasted your time! repeat on other side.
the driver side there's the same screw on the drum above the brakeline. repeat above provess. fill master cyl again.
hambandit
or you can make a bleeder kit and not waste the fluid. either way works the same in the end
kia swap
last post by Brody 12 mo
51
