Mazda Engine General \  check engine light
check engine light
views 662
replies 4
racin36er   +1y
here's the scoop.
picked up a 91 b2200 about a week ago. truck is in amazing shape, just under 88000 km when i bought it. tonight it rolled over to 89000. at about 89005km the check engine light came on. it could have been at the 89000 mark, i just noticed it at 89005. anyways. the truck is running GREAT, nothing out of the ordinary. i've heard that there is an emissions warning that does come on -- is this whats happened? if so how do i fix it?
i did notice that the engine was low on oil (just below the 1st mark on the dipstick, so it was running low. could this have caused it as well? i topped it up. didnt change, lights still on, which leads me to believe this isnt it.
any help would be greatly appreciated. thanks!
speedster93b   +1y
check all your vacuum lines and sensors
madlowmazda   +1y
the check engine light is used strickly for the EGR maintenance replacement interval at 80000 miles- 89000km or 120000 miles- The light automatically comes on at these intervals to remind you that EGR valve replacement is suggested. To make the light go off- locate the 1 pin connector underthe driver side of the dash board- it will have an empty unsued connector right beside it- switch these connectors, and the light is off!
racin36er   +1y
awesome. thanks!
*edit*
worked like a charm. thanks a lot!
speedster93b   +1y
EGR reminder intervals are not the only reason it comes on.
