Mazda Engine General \  87 b2200 smoking like a siv
views 1729
replies 3
faded   +1y
i have been reading on the forum that if it just smokes on startup it is just the valve seals? i have had a friend that said it was my rings it smokes for like a good 4 minutes or so when started then it stops so what could it be? and do i need a new head or could i just get a valve job on the head done?
toddluck   +1y
if its the rings it will smoke all of the time its the valve guide seals im sure,,,,,mine smokes until all the oil that has leaked in during the night gets burnt off
faded   +1y
sweet so i will just get a new head. and another question is it a pain in the ass to do rings? because if its not i will just do them when i put my new head on etc...? and if anyone is needing a head i found this guy on ebay
pont   +1y
Thats not 100% correct If you have a broken ring it will smoke all the time. If its just stuck then it will smoke till the rings heat up and pops out. You can have your head redone Last time I checked they were gone charge me 100 bucks plus cost of new valves if I needed them. You can try seafoam and see if that helps.
also check the PCV valve Mine would smoke till it wormed up till I replaced that does not do it as bad now
