Turn Key Power lights and everything else.. But Nothing in
bigbsautos
Engine.. All I can hear is the power clicking abit at first turn like when you turn it to on..
All I did was put a bar threw the cad cause it was clogged..
Went to start and nothing just power juice then it started... sounded good then I trurned off and tightened a few things and went to drive it and nothing agian....
Now Im thinking it has something to do with the ignition switch?
I checked coil its giving power.....
So any ideas? Reading manuel now...
Thx
~B~
midnightmike's avatar
midnightmike
starter soleniod?
tap the starter spoloniod if that works then thats the prob but i would say ign...switch
hex0rz
Starter solenoid...
Or ign. switch.
Lol, just like what they said above! One catch!
1. If its the ignition switch, it will be hard to have the OFF, ACC, ON, RUN positions. For every setting on the ignition, you should distinctly feel each transition! If it just kinda goes through them without the normal feel of the turn, then its the switch!
2. ALSO! One simple thing to check before anything else! You say you have power, but I would still check your cables and see if the terminals on the post are on and not corroded!
madmazda
I had this problem before...At first mine was doing that, I banged the snot out of my Starter, it started no problem, after time the Starter solenoid died, i had to buy a new starter...Installed in within 20mins, same thing was still happening, Cleaned my battery posts really well with a post cleaner, including the terminal cables...it hasnt happened since. I bet its your Terminal cables, theres corrosion build up on there...
kia swap
last post by Brody +1y
51
