timeing or distributer shaft
hb
my b2600I will run for a short period and then a white puff off smoke will puff out of the airfilter do i need a new distributer shaft or just a timeing done
speedster93b's avatar
speedster93b
did you recently do any work (timing belt or head work) where you removed the distributor?
hb
i didnt do anything just got the truck for free
hex0rz
I'd be checkin' both! It sounds more like a timing issue. I don't understand how it would run for a short period and then puff smoke? Does it die right after? It may be something else actually... But you are having spit-up through the carb, so timing is an issue here...
hb
yeah it will run for like 2 seconds and puf out white smoke and shut off
speedster93b
your distributor might be misaligned... like 180 out or something
kia swap
last post by Brody +1y
51
