WEBER NOT RUNNING...PLS HELP
costa__86@hotmail.com's avatar
costa's avatar
costa
So i just got in from work at midnight and noticed my idle was kind of high so when i got in i thought i would do a quick adjustment in the dark...well dont you know as i was just touching up the idle mixture screw under the choke my screwdriver touched the choke and caused a spark then the engine died and wont start again. I know i blew something just please can someone tell me how deep of shit i dug myself into or if its just a fuse.. well going to bed but going to check back on the issue in the morning. thanks for any help
mullet
Did you notice where the spark came from? Most likely its a fuse.. but now the fun part is where is the short... aka the broken fuse. I would pull out your multimeter and a friend and try to find the broken fuse. If its not a fused wire.. then you have a short somewhere and need to cut out the bad part of the wire and replace it w/ an approperate sized fuse. Good Luck
Mike
mullet
BTW.. i'm unsure how you would have arched it unless you had a previous eletrical problem, or you touched the screwdriver to the alternator/battery terminal. Your idle screws shouldn't be hot aka carying voltage.
Mike
costa's avatar
costa
i had the screwdriver on the idle mixture screw and as it touched the bottem of the electric choke assembly or w/e you want to call it it had a spark right there which gave me reason to believe i f'd up my carb...going to check all the fuses right now hopefully all is well
slammedyota91's avatar
slammedyota91
any update?
costa's avatar
costa
yup yup was just the fuse in the cab labelled ENGINE...boy am i happy:)
kia swap
last post by Brody +1y
51
