Mazda Engine General \  Weber 32/36 and timing
views 1683
replies 12
following 5
87mazdamini   +1y
What are you guys running your timing at with your webers?
hocbj23   +1y
5 degrees BTDC.BJ
toddluck   +1y
did you get your weber installed?
hex0rz   +1y
6 BTDC, just like Mazda says to run it at... I've had no better luck with the timing than it being at 6 degrees. I did'nt notice much of any performance gain by changing the timing. Having it at 6 degrees is better. You wont face the problem of carb spit-up and your emissions will be cleaner...
rocketalpha   +1y
Timing is one of those things you should adjust with care.
HeX0rz said it the best, for the best performance set timing were it is recommend by factory.7 times out of 10 people say they get serious gains from adjusting the timing, there timing belts are wearing out and the adjustment is a very temporary cure.
I would recommend you set your base timing, then adjust the carb as needed. Also check you plug condition after a few days to if you are running to rich or lean. Perfect comdition should leave a color simular to a brown paper bag.
87mazdamini   +1y
Cool thanks guys. Yeah toddluck I got it on before the fourth I got pics in my garage. Took me about 2 1/2 hours and I put a new fuel pump in too.
toddluck   +1y
87 where did you pick up the filter on your valve cover?????
87mazdamini   +1y
Autozone for 6.99
toddluck   +1y
crap!!!!...we dont have autozone here
hocbj23   +1y
if a weber is all u have done,i would stick with the factory timing of 6 degrees BTDC.I hsve a hotter ignition , a 272 cam and some other mods and 5 degrees BTDC is where my truck has the best performance.BJ
