HELP FAST clutch!!
fanninator@yahoo.com's avatar
HELP FAST clutch!!
fanninator's avatar
fanninator
well this time....my clutch wont engage, we bled and bled it but no luck, she still goes to the floor and i dont no shit bout this...can anyone give me a suggestion? -bf
hocbj23
the reservoir for the clutch is on the firewall.Check fluid level.ALso check rubber seal around the reservoir cap, ru leaking fluid?BJ
watt's avatar
watt
i was lost all my fliud and was at a stop light and had to turn the truck off to put it in first and start it up and just give it gas so it wouldnt stall on itself then shifted without the clutch...i just needed a slave cylinder but if you already bled them then i dont know.
speedster93b's avatar
speedster93b
if your clutch won't engage, as in won't go? maybe your springs in the clutch are bad?
fanninator's avatar
fanninator
well from what paps figured out...slave cylinder. so im out of a ride for ~2 weeks because idont have any money...worst part is, its only a $17 part!!!
watt, how did you shift w/o the clutch, a buddy showed me in his truck one day but i forgot.
thanks guys -bf
dropped90(justin)'s avatar
dropped90(justin)
u just kind of have to be easy on it. you have to let it drop rpms a few but catch it and switch before it gets to low and puts it back into a bind.
justgettinstarted
its not really something you need to do for 2 weeks haha.
dropped90(justin)
i think he just meant its goin to take him 2 weeks to save the 17 bucks. damn i thought i had it bad
kia swap
last post by Brody +1y
51
