Mazda Engine General \  Any help for someone who has absolutely no idea about engine
views 1263
replies 13
following 8
mazdagurl   +1y
ok so i am driving along and my check engine light comes on and is staying on for the first time ever when i stop it goes on when i go it goes off and then as i am driving it blinks on and off so i am thinking oil but i checked my oil 4 times and my oil says that it is full so any help?
maybe the wire to the light or what any help would be appreciated
sarah
slammedyota91   +1y
mine does something similiar, it comes on at a steady speed and goes off when i accel or decel, its a smog thing of of your sensors is plugged on it. i smashed my throttle good for about 2-3 miles just floored and it stopped coming on, lol so im sure i cleaned out whatever was stuck in it, lol. our trucks computer only works with the smog on it, it controls nothing else.. so its the only thing it could be.
laydoutb26   +1y
psst... get a weber carburetor!
hocbj23   +1y
The check engine light is programmed to come on when one of your pollution control devices needs servicing,usually the EGR valve on the side of your carb.If u have checked oil and it is ok, u have several it,unplug the bulb(not recommended) or get the EGR valve cleaned,which u can do yourself if so inclined.OR I or several other guys around here probably have a clean one laying around we will send u.Let us know.BJ
mazdagurl   +1y
thanx for helping i will check all this stuff out yeah i will be getting a weber carb
Cusser   +1y
The check engine light (called the Malfunction Indicator Light) also comes on at specified intervals like 60K, 80K, 120K, and 160K miles (hopefully so you'll take it to dealer to get it re-set, and they can try to sell you service and timing belts, etc.). If that's the reason, two wires under the dashboard, extreme driver's side must be swapped, then swapped back the next time this happens.
mullet   +1y
cusser is exactly correct. If you crawl under the drivers side of the dash board you will see a connected harness and another identical version of one side. Unplug the connected harness and replace the match w/ the unused.
Mike
mazdagurl   +1y
hey thanx i will try this too and see
hex0rz   +1y
If you get the Weber carb, let me know, I will help you install? lol... Only if you need help.
slammedyota91   +1y
doesnt it come with instructions?? lol and im sure her hubby can help her..
you crack me up lol
