Mazda Engine General \  302 coil help
302 coil help
views 552
replies 4
following 2
2slow5.0   +1y
ok im trying to start the 302 in my truck. the problem is there isnt any fire to the plugs, well i know its the coil, due to i dont know how to hook it up. i know 12volts goes to the +side. but i dont know were to go with the neg "-" side. my factory ford distributor doesnt have any wires coming out of it. none, no plugs no nothing. all thats inside the cap is a rotor, no electronics what so ever. im also tring to use my stock mazda coil for they looked the same. (mazda vs. ford)
i want to hear this thing run and i cant!!!!!!
hocbj23   +1y
I know there are folks here with 302s in their Maz so I am sure they wil be more help than I .Just a couple of thoughts though.I doubt that a stock old Maz coil is going to be able to overcome the resistance of 8 plugs and wires and fire the 302 like it should.May be wrong here but if u get a spark it wil be weak.Secondly,the alternator and its connections are the primary ground source for a Maz.What kind of alternator r u running?One wire GM,Ford or stock Maz.U got to have some kind of wires coming out the distributor-ie a wire to the coil,plug wires,and static suppresion grounds.R they there and hooked up.BJ
2slow5.0   +1y
running the ford alt off the mazda wiring. and no im not nuts, the dist. doesnt have anything coming out. the injection consisted of 2 normal injectors setup in a tbi form. im trying to find the coil that was on the 302.
i checked again with a test light and the light does come on at the coil as well as the coil wire at the cap.
i have never seen a dist. with no wires coming out of it before, but thats the way the car ran before i pulled the motor out of it. it ran great and drove good
incase it helps.... i didnt want to run the tbi, but the intake is the same as the normal 2 barrel carb would use. so thats what i did
hocbj23   +1y
I know there are wireless ignition.My Volvo R runs coil packs for each cylinder,thus no plug wires.Have never seen a 302 with wireless ignition so I am at a loss.Does ur 302 have multiple coil packs for each bank of cylinders perchance-thus no wires?BJ
2slow5.0   +1y
no no no. its normal. has a dist. with no wires going to it. the cap has nine nipples, (8 plugs wires, and coil) it looks like any other 302 v-8 just the dist. doesnt have any hookups. all it has inside it is a rotor, no pick ups or points.
edit............. wait a min. ok i got it! when you said wireless it reminded me of crank triggers. i forgot i tossed the old crank trigger thinking i didnt need it. i thought it was there to fire the injectors, but i found 8 slots in the balancer! ok so i have to get another dist. ok no biggie
thanks for the help
