Mazda Engine General \  problems
problems
views 822
replies 13
following 7
acrohotdawg   +1y
hey guys ,i just got this mazda running,sorta . i have oil coming out of the exhuast and or the freeze plugs,my question is can i unbolt he tube that bolts to the manfold and plug the four holes,all the emmisions are either plugged or have bolts in the hoses,im trying to save for a weber downdraft, also i have oil coming out of the botom of the manifold before it ties into the cat ,am i making sense?if not here are some pics ,i need a remedy for this.im sure ill have more problms. thanx in advance
slammedyota91   +1y
how did you manage to get oil into your exhaust? but yea you can cap em off gm lug nuts fit on em
mazdatweaker   +1y
post deleted
Post was last edited on May 14, 2009 06:05. This post has been edited 1 times.
hocbj23   +1y
If u indeed have oil in the exhaust u have a plugged #1 CAT for sure.I also see oil on the valve cover- ru sure u just dont have a bunch of leaky gaskets? Much cheaper to replace gaskets than rebuild a motor.BJ
acrohotdawg   +1y
yeah the vavle cover gasket is good just replaced t , so if i buy a header and do away with the cats i should be fine? we dont have emmissions,here so i dont have to worry about that .
dropped90(justin)   +1y
yes you should be fine but if the first one is clogged i would look in to checking out the second one as well.
-justin
draggin84   +1y
i had oil in my exhaust and it was caused by bad rings.
acrohotdawg   +1y
well when its running there is a ton of white smoke, but most of it is burning off of the manifold , the truck runs really strong , no knocking no pinging really good throttle response no lifters clicking , im hoping i can can just replace the exhaust and carb and drag the piss outa italso this is what im ordering as soon as i get some cash.
draggin84   +1y
was the truck parked a long time and you had to break the engine loose?
acrohotdawg   +1y
no it was having carb/choke problems
