Mazda Engine General \  i need wiring codes for 86b2000 ignition switch
views 1887
replies 8
posimazi   +1y
sick of not having wipers or heat when the truck was repoed the ignition was drilled out and since i have put in push button start and only used the wire off switch for the starter. i believe that somewhere in the other 7-8 wires lies the issue of not having heat or wipers and stuff. radio is hard wired so at least i have that but tonight after relocating the gas tank i went for a drive and with rain and windows steaming up caised some issues that so far i hadnt worried about, minitruckers like to ruff it but i am in south dakota. hook me up with the color codes thanks. ps got my york all hooked up,, thanks for the assistance wish i could find my hanes...
doubledamnit   +1y
this might help
,-B2600/print_wiring_chart.asp
toddluck   +1y
you need to find your acc wire and toggle that as well
posimazi   +1y
i have accessory toggled and then push button for starter wire but still no blower motor or wipers
toddluck   +1y
but it sounds like you only have ignition not acc........check fuses and relays...do you have turn signals??
posimazi   +1y
i have blinkers and they work fine checked all fuses and relays either i have other wiring problems or there is more in that wiring on the ingition switch needed to run the heat controls fan and the wipers .
posimazi   +1y
well i thank everyone for there info i now have wipers and heat south dakota thanks you for your help dont know that i will plow snow for them but will drag my ass around got ac compressor running my air and got the back done with tank relocation. as minitruckers most of us didnt go to school for this but with dedication anything is posible.
posimazi   +1y
posimazi   +1y
