tranny ?
tranny ?
pudd46
will the tranny from a 2.0 or a 2.2 work on a 2.6
mazdamn's avatar
mazdamn
yup
nytrdr24's avatar
nytrdr24
the 2.0 or 2.2 tranny will fit in a 2600 truck, but will not mate up to either 2600 motor....the input shafts on the trannys are different.
87-93 2.0 & 2.2 tranny input shaft 8 7/8" long, 15/16" dia., 22 spline
87-89 2600 tranny input shaft 9 7/16", 1", 23 spline
90-93 2600i tranny inp shaft 9 3/4", 1", 23 spline
you can go to centerforce.com, and do the drop down boxes, and it will give you the specs for the trannys inputs....
the same tranny in the 2.0 & 2.2 trucks was used in non turbo cars in various years, the difference is the bellhousing, tail sections, & slightly different gear ratios.
same goes with the 2600 trannys, they were used in turbo cars during various years, just different bellhousings, tail sections, & slightly different gear ratios
pudd46
thanks for the info
nytrdr24's avatar
nytrdr24
no prob, glad to help!
kia swap
last post by Brody +1y
51
