Mazda Engine General \  warped head
warped head
views 797
replies 9
roger26i   +1y
hey i have an 87 b 2000 and the head is cracked and warped i was just wandering if anyone might have a good one layn around some where man it sucks not bieng able to drag especially when i just got new sheet metal and some drag blocks
lofosho86   +1y
don't know if it helps or not but i got an extra head off a 91 b2200!let me know if it helps!
hocbj23   +1y
I live in Chattanooga and I have a head.It aint laying around it has been tanked,inspected and redone .Has cam, lifters and valves.Nice head.If interested let me know and I am sure we can work something out.BJ
pont   +1y
I have a head as well I'm in Lexington (Henderson, TN) I had it checked when I redone the head gasket and it was good. I then scraped the truck (motor was fine) give me a holler if you and BJ can work something out.
roger26i   +1y
i really appreciate it but will it work?
Post was last edited on Nov 09, 2007 04:11. This post has been edited 1 times.
roger26i   +1y
what kind of head is it ? 2.0 or 2.2 i was told they were different but im not an expert on that . its just that i had a 2.2 head on it and it kept blowin gaskets then i put a 2.0 head on it and it was fine , i just forgot to put water in it when i got it linked and it over heated severely
pont   +1y
the heads are the same its the lifters that are different. you cant run the 2.2 lifters on a 2.0 block. Mine is off a 86 B2000 and it will need the 2.0 lifters cause I put them on my 92.
hocbj23   +1y
Mine will work on ur truck and it has cam lifters and valves already installed.Plug and play.BJ
roger26i   +1y
they are solid lift cam to rocker ley dont have lifters the old ones do thopre 86
roger26i   +1y
i found a 2.2 and tranny with weber 30 header and cam wit less that 300 miles for 500 bucks that should be a good deal
