Mazda Engine General \  b2200 in a b 2600 truck
views 515
replies 2
following 2
oregonmazdoger   +1y
i might be getting a b22 and was wonderin if the motor mounts will work in the b26 and what i have to do to the tranny so i can use the b26 trany and rear end for the higher gearing
elbine69   +1y
The b2200 motor will go in just swap the motor mounts. Youll have to use a b2200 transmission because the b2600 transmission will not bolt up to the 2.2 motor. The rear ends are basically the same just different gear ratios.
oregonmazdoger   +1y
cant you bolt the bell housing off the b22 to the b26 in the place of the b26 bell housing and have it work
