fuel out of exhaust
fuel out of exhaust
offroadcrazy
this one is kicking me in the butt i drove my truck the other day to work and when i got in it to go home it started then stalled after that im geting fuel to come out of my exhaust.
iv tried to jump the leads on the ETC to tell the comp the engine was worm to lean the fuel but don't change still strait gass!!!
what am i forgetting to check? anyone know?
mazdatweaker
post deleted
Post was last edited on May 14, 2009 06:22. Edited 1 time.
offroadcrazy
i wish it was that simple its fuel injected 2.6 Im so lost yeah i gotta change the oil
ranger5.0
Sounds like you have a injector stuck open or a bad fuel pressure regulator.
offroadcrazy
yeah i have a injector tester man I'm feeling lazy
how would i test the regulator?
ranger5.0
You need a fuel pressure guage. Get the spec for your truck and put the guage on see how high it is. There should be a vaccum line on the regulator, pull it off check if there is fuel in it. If there is the diaphragm is prolly gone.
offroadcrazy
i figured out it has a bad pcm by doing what is know as a bump test (tap on the pcm cover).
kia swap
last post by Brody +1y
51
