quick question will a weber carb that came off a mitsu mighty max 2.6 engine bolt right up onto a mazda b2200 2.2 engine? or if i have to get the b2200 adapter kit then will it work? please let me know.
dropped90(justin)
figure out the part number on the carb to be sure. if its for a 2.6 then its probably atleast a 34. i have a 32/36 on mine. i would think the adapter plate would have you set on the swap but cant speak from experience.
-justin
pepehn
if it doesn't bolt right up, nor use the adapter kit why dont you take it to a machine shop and get them to make you one
ga,mazduh
who makes a weber carb kit for thses trucks cause i really would like to buy a whole kit instead of havn to monkey with all that vacuum sh*t. plus it will clean up under the hood somemore......ed.customs wreckn sheetmetal on tha daily
90-b22dawg [andrew]
this site will tell you everything you need to hook up a carb and step by step instructions
pennywise
since we are on the topic of carbs what would be the best one for reliability and to get rid of the emissions junk for a b2000?
dropped90(justin)
weber will get rid of all your emission crap and computer. you just have fuel and air, and a vacuum line for your dizzy and thats it unless you hook up a line to your charcoal cannister. webers are reliable as well more way more reliable than the stock nikkis in my opinion and when you buy the whole kit from a place it will come with step by step directions to install it.
-justin
pennywise
ok what ones are there and what should i get for fuel economy, cleanliness, and simpleness.
dropped90(justin)
just go with the k675 that is the part number it will be a 32/36 weber
