Mazda Engine General \  Timing chain tensioner adjuster.
views 871
replies 1
following 2
jules winfield   +1y
Anyone know how to adjust the tensioner? I have a 1992 B2600i, 5-speed. I blew a head gasket and hope to God I didn't crack the head, I need to pull it off but need some slack in the chain to drop the came gear to get the head off. Anyone know how to adjust it?
jsulen   +1y
- Pop the latch and open your hood. Secure it in place using the locking rod.
- Disconnect your car's battery.
- Locate the timing belt and related apparatus. You may need to consult your vehicle's manual to find where the timing belt is located within your engine.
- Remove the timing cover.
- - Relax the timing belt's tensioner. To do this, you'll need to loosen the bolts that hold it in place. Allow the tensioner to release so that it comes into easy contact with the timing belt.
- Adjust the timing belt as necessary. If its course has been disturbed, locate the problem and correct it. To complete this step, you'll need to consult your car's service manual or ask for some assistance from a pro.
- Compare the timing marks to make sure that the timing belt is on the right course. Look for timing marks on the crank, the cam and the sprockets. Make sure that they are all aligned evenly.
- Turn your engine manually by using a wrench to manipulate the crankshaft pulley. You should complete a couple of engine revolutions to make sure that the timing belt is properly seated in relation to the sprockets. Make sure you're not experiencing any resistance as the belt turns, and check to make sure that the pistons and valves do not touch each other as the timing belt completes its cycle.
- Tighten any of the bolts you've loosened along the timing belt tensioner. Make sure that they fit snugly, but don't over-tighten them. That will make it more difficult to remove them the next time you need to adjust your timing belt.
- Reconnect your car's battery. Slam the hood and make sure it locks into the closed position.
- Turn your car's engine on and check to make sure that everything is running smoothly.
