Temp Sensor Wire
lofosho86@yahoo.com's avatar
Temp Sensor Wire
lofosho86's avatar
lofosho86
Does anyone know or have a pic of which wire goes to the temp sensor on the motor?Mine got snipped during engine swap and not really sure which one to hook back up!thanks guys!!!!!!
lofosho86's avatar
lofosho86
surely someone knows!please!!!!!!
immortal1 (linn)'s avatar
immortal1 (linn)
This should help. Not sure if you wanted the wire from the computer or the temp gauge on the dash.
lofosho86's avatar
lofosho86
thanks Immortal!that helps,i needed the one from the sensor to the gauge!
Cusser's avatar
Cusser
Being a former mechanic, Phi Beta Kappa, Magna cum Laude graduate (so why do I drive a B2200?), I thought I'd consult my '88 Factory Manual to help you. As usual it was no help in all in helping with its location for your B2200. So I opened my hood to look. The temperature sending unit is located just under the radiator hose where it connects to the thermostat on the front passenger side of the engine. It's somewhat hidden from above so you may need to hunt for it. The wire going to it is yellow with a white stripe
lofosho86's avatar
lofosho86
thanks cusser!thats just what i needed!!thanks alot guys for responding so quickly!
kia swap
last post by Brody +1y
51
