Mazda Engine General \  302 oil pan vs crossmember issue
views 728
replies 3
hambandit   +1y
im having some problems getting the motor in and i was wanting pictures of what you guys did to your oil pan or crossmember to put it all together.
ive currently got a double sump pan on it and dont mind converting to either front or rear sump but want to make sure i buy the right one.
I'm using the mounts where you have to "waller out" the holes on the frame for the big ol bolt on the bottom of the mount to go through. not sure what theyre out of.
I'm also wondering about pan to pavement issues, the truck is bagged so obviously having the sump above the crossmember on a horizontal plane is the only option.
any help is appreciated
baggedb22   +1y
i do not have any pics of mine but i notched the center section of the crossmember and then replated the bottom of it and made a mean skid plate to save my oil pan!
stumpy   +1y
I dont have any pics of mine either but if your talking about the crossmember held on with two bolts on either side I welded plates on mine and extended them like the size of the member and mine fit like a glove.And is plenty high off the ground and im sitting on my bump stops but im not bagged
anguswilly   +1y
i just moved the c/m back on the bolt holes and got a spare c/m to cut up as spacers,works great for last 70000 kms! btw i,m not using a mount kit
i got stock mustang mt on driver ,stock maz on pass
holds 485 rwhp no prob.
