auto to 5 speed
auto to 5 speed
hayanxpocho69
ok im gonna pick up some stuff to do the swap but my question is that since i have a ex cab, do i have to get a 5 speed b2200 tranny from another ex cab? or can i use a standard cab 5 speed b2200 trans also?
and i think i got everything....trans clutch pedal assembly, mass cil. hard lines
pont's avatar
pont
Yea there the same but you will need the drive shaft out of a ex cab.
hayanxpocho69
so my exsisting auto ex cab drive shaft wont connect to the 5 speed trans?
pont's avatar
pont
check the length the auto tranny and 5 speed I think are different lengths. Which will make the drive shaft to long or to short. I might be wrong so check it out while your there.
bluebomber's avatar
bluebomber
No the auto trans extension housing is longer so the shaft is shorter. I have done the swapped and I just had a a new shaft made because you cant replace the u-joints if there bad. Mine were bad so thats what I did. I had a solid one piece aluminum shaft with replaceable u-joints made. It shaved about 35lbs or so off and gave more power to rear wheels. I think it was worth it. Chow
kia swap
last post by Brody 12 mo
51
