Carb to EFI swap?
Carb to EFI swap?
project_uno
Alright i just bought a mazda b2000. for 75$ the carb is screwed up the guy had it in a garage most of it life..... im not going to buy a 549$ carb. i wanted to know and i searched didn't see anything about it.... if i can swap over to EFI
Are theses the only parts i will need?
ECU
engine harness
throttle cable
intake manifold & gasket
Am i missing anything?
And i found a B2600I FI would that swap over? they had the same motors
hocbj23
B2600i and B2200/2000 engines have nothing in common and the FIs will not swap.If u put an FI unit on a 2000,u willalso need the in-tank fuel pump from the 2200i plus some other stuff I prolly havent thoght about.BJ
project_uno
Alright so i need to find a b2000 or b2200 FI setup... and fuel tank pump.. prolly the fuel lines too.?
just buy a weber and call it good
project_uno
I thought about it but for 549$ i could swap something else into this thing.
low mazda's avatar
low mazda
dude you can get weber's all day long for 299 on ebay...
project_uno
Really? could you link me to some?
elbine69's avatar
elbine69
$289
project_uno
thanks.
pont's avatar
pont
Finding a FI B2200 is not gone be easy they only made them for like 2 years and even then was mostly in Canada and California. You could use the FI off of cars like the 626 or ford probe. But they could be a pain to install and get working correct. The weber is not like most carbs tuned right you get great MPG and lots of power.
kia swap
last post by Brody +1y
51
