Mazda Engine General \  alternator belts
alternator belts
views 828
replies 10
following 8
b22low   +1y
hey guys maybe a stupid question but any ways... i changed all my belts when i replaced my alternator about a 2 or 3 months ago give or take, and my alternator belt has been tightened about 3 times since and today it snapped right off i replaced it today and ask the guy if there were any other more high quality ones. 10 - 4 negative on that one and now its quite.
my question is: Is that the normal life of this belt or have i done something wrong?
slammedyota91   +1y
these belts last a long ass time lol. myaybe you tightened it too tiht,
hocbj23   +1y
when u tighten a belt of any sort,put a straight edge from pulley to pulley,put ur thumb in the middle of the belt and press down.You should be able to deflect the belt about 1/2 inch.anymore it will slip,any less and it will wear prematurely or break.BJ
90-b22dawg [andrew]   +1y
over tightened it....
framedragger2   +1y
just a question, have you checked for misalignment of the pulleys? it was proly just too tight though.
Cusser   +1y
I always use Gates belts from CarQuest on all my vehicles. I did have an alternator belt break once after about 6 months and they replaced it for free. The alternator belt and the power steering belt shouldn't be as tight as the AC belt.
b22low   +1y
thanks man ill check that out
Cusser   +1y
Why did you re-tighten the alternator belt "about three times" since replacing the alternator? With the belt off, spin the alternator by hand to see if it has a bearing problem, shouldn't take all that much to spin it.
b22low   +1y
i re tightened it because it kept coming loose and it would whine like no other!
mazdamn   +1y
alt bearing's GONE.
