my driveshaft stripped out or something where it connects at the carrier bearing. its on a extened cab 5spd 87 b2000 anyone know what i could do or what happened?? and can the b2000 driveshafts have new careier bearing,boot the whole assembly put on?? the guy I talked to said the b2000 driveshafts didnt have removable ends or something? and are the b2000 and the b2200 driveshafts be interchangable??
mark
you can replace the carrier boot and joint...but u cant replace the ends....well you can replace the ends actually.....you have to find special staked u joints
go to
mark
go to that site for the end ujoint...but u can just buy the carrier ujoint at local parts store
laiedmazda87
all i need trop replace is the rubber boot. its ripped.
mullet
screw it.. you should be fine.. unless you live down a dirt road.. mine ripped off about 2 years ago.. no problems.
Mike
laiedmazda87
it makes noise real loud and viberates some
mark
lemme check on it...i know u can get the joint, but im almost positive u can get that boot somewhere
