What do you need to do so you can swap to a S-10 or some 4 bolt pattern? I have been looking for some 6 bolt rims to tuck and I think it would just be easier to swap lug patterns. Any ideas?
dawgsledmazda
I make tube arms for Mazdas that can use either a Toyota or S-10 spindle. plus the lower arms are A shaped to eliminate the strut rods. plus they have a bag mount and correct balljoint angles to lay out. hit me if you need some
miked
offtopic but how are you doing on th BYC s10 tube problems.
pro-rabbit
Got any pics of your work?
drtyhatch
Mother goose customs makes a bolt on 5 lug kit for the front but its expensive, i think the last quote i got from them was $450. includes everything need to just swap it out though, just pull off your bearing and rotor assembly and just bolt the new one on.
speedster93b
How much do you want for a set of arms? shipped to Eugene Oregon?
roknmotor
Is it possible to use an older ranger spindles and rear axle to change the bolt pattern?? i am looking for a cheap 5 bolt conversion!
bigroy_80
you could have them redrilled, thats what i did. front redrilled and toyota rear axle which is 3 inches narrower so thats another plus for that.
