how much cutting is involved in bagging the front of a mazda, and what needs cutting
mullet
Not much really.. i took out the sway bar and the torsion bars.. had to grind down the hump on the lower controll arm to mount the lower plate, and then welded the top part of the torsion to the frame rail. The bigger the bag.. the more lift you get, but also the more work and cutting involved.
mike
mazm
thanx for the help
minimazda93
dude if you are going to drive the truck often you need to cut everything off the frame until you have just the flat rail there(bumpstops/mounts, and that hump below the shock tower) or else the bag will rub.
and MAKE SURE you plate the frame with a piece of 3/16" because the bracket WILL break off the lovely 1/8" mazda frame
paul42
Do you guys want to post some pics of the front of yours? Also can you keep the sway bar?
mazm
thanx for the help i am fixin to start bagging it soon
minimazda93
ive never seen anyone keep the swaybar b/c its in the way of the bag however if you were a badass you could take it off and maybe bend it and build a new mount for it, im thinking of doing this
