DJM Drop Control Arms (Question)
saggiosrp@comcast.net's avatar
saggio's avatar
saggio
Has anyone on here installed the DJM Drop Control Arms?
They drop the front 3".
What are the pros and cons as far as using the Drop Control Arms or using Drop Spindles?
Click below for picture and info.
[/quote]
rollinslow
I have never used the control arms but I have heard that they give you alot of negative camber and not good to use if your going to bag the truck. I think its mostly clearance issues with bagging but not 100%. Spindles maintain the camber alot better. Not sure if there really is any cons to using spindles when bagged. I'm sure someone will come up with one though.
saggio's avatar
saggio
Thanks for the reply.
Maybe I'll just go with the 2" drop spindles then.
I'm not bagging this truck.
stock_fat0727
i would go with the spindles. i had the djm arms on my truck with bags and i went through two pairs of bags before i just gave up on them. the problem is the way the control arms lower the truck is by raising the lower balljoint and that leaves you with no clearance for the bag when it is deflated and it rubs the ball joint bolts
stock_fat0727
sorry i didnt read the part where u said u werent bagging the truck but i would still go with the spindles and flip the ball joints
