Mazda Lowering Static \  pulling leafs
pulling leafs
views 1481
replies 9
following 9
mazm   +1y
i have 3 inch blocks with all the leaf springs in my mazda, i was wondering how much lower it would get if i pulled the overload out?
mullet   +1y
LEAVE THE OVERLOAD and the biggest leaf.. for safety reasons. The overload will keep the main leaf from dearching over and snapping.
Mike
mazm   +1y
well how much would it lower it if i pull the middle two out
thetornado   +1y
mine dropped about 2-3 more inches with the 2 leafs out...
slims   +1y
I need to take at least one out. I have about 2" of rake.
midnightmike   +1y
if u pull both middle leafs out it'll give an easy 2.5-3" drop basiclly eliminating all the wheel gap
nothinbutcowboy   +1y
i took the two middle ones out with a 3 inch block, and on my factory wheels im so close to tuckin, if you take the leafs out, and throw them in the bed you tuck a lil
gwadzam   +1y
how do you go about pulling out those leafs, i want to try it before i buy new ones.
delawaredime   +1y
if you do one side at a time and take your wheel off its really easy.
just undo your ubolts, jack the axle up to take the pressure off, eitehr cut or unbolt the center pin on the leaf pack, slide out the 2 leafs, put the pin back in, may have to cut it down a little, put your ubolts back together adn there you go...
lol, im not really good at explaining things
madmazda   +1y
JUST SAVE IT AND DO AIR...lol
