Mazda Lowering Static \  Change pinion angle? Driveshaft?
views 1054
replies 5
following 5
groupone   +1y
How low can I go in the back without having to use pinion shims or change any driveline stuff? Can I just use shims with 3" blocks or do I need to alter other stuff? Thanks
grantkustoms   +1y
3 INCH BLOCK YOU SHOULD BE FINE
mullet   +1y
Yeah agreed ^^^
groupone   +1y
What about if I also removed a leaf? How much lower would removing 1 leaf make it?
mark   +1y
you'd be on the bumpstops if you remove a leaf and 3inch blocks
slammedmini469   +1y
my old mazda was shaking like crazy with 5 inches of blocks (a 4" and a 1"....i didn't do it, was like that when i got it)
so i took out the 1" blocks and left the 4" blocks and the problem was fixed, so i would say you would be safe with a 4" block....but dont hold it against me if you have bad pinion angle problems....
also, i had about an inch of suspension travel with NO bumpstops......so im not sure if leaves were removed or not...
i know up front, i had about an inch of tire-fender clearance with (i think) 195/45-14 tires......so it was pretty low....about 3 inches of ground clearance under the frame i think.......
GOD I MISS MY MAZDA
