Mazda Lowering Static \  baggs
baggs
views 991
replies 4
following 5
mazm   +1y
what is the difference in 2500 and 2600 pound baggs
mullet   +1y
2500lbs bags mean exactly that.. they can support up to 2500 lbs (pounds). The 2500's are skinnier and don't get as tall, but don't need as much PSI to lift as the 2600's are taller, fatter, and need more of a push. 2600's also give a little bit of a smoother ride IMO! However i have 2500lbs firestones on all my corners!
slammed83mazda   +1y
I believe mullet gave you the best possible answer, only reason im not going to 2600 bags in the rear is cause they take more pressure and i dont need my compressors running constantly on my tiny battery.
nothinbutcowboy   +1y
how do they rate the bags?? if it is a 2500 bag, do they take into consideration both sides? so it is 2500/2 or is it 2500 each, so 5000 pounds? How heavy is the front end of a b2200?
whynotfab   +1y
Click here for Info/Specs on Contitech Airbags
Click here for Info/Specs on Firstone Airbags.
Click here for Info/Specs on Slam Specialties Airbags.
Those are 3 pages that I found that might help you out, they have some pretty detailed technical stuff too.
